Global Switches don`t work & Lights control
  • Global Switches don`t work & Lights control
    1.Reflection/Refraction - unchek - it`s work...
    2. Glossy Effects - unchek - it`s work...
    3. Light in Rhino render:
    4. VrayLight in VRay Render... without any settings...
    Regards, Triar
    Yes your first two issues are items that are not properly hooked up. However, I'm afraid I don't follow what the third issue is. Also, could you explain how you come to have the light properties page not show up? I've tried selecting one ouf our lights, then switching renderers, then switching back, but my light page does not disappear.Any clarification would really help. Thanks
    Joe Bacigalupa
    Developer
    Chaos Group
      same bug here. In Beta 5 I tried it, and there isn't any settings. I tried button "Object propereties" (of course light was selected) and then I selected "Light" from list, nothing. F3 to open Obj. propereties, -> Light, nothing...
      Jiri Komon - DarkLight
      13 years, Czech Republic
      darklight@cgart.cz
      http://www.cgart.cz
        Can someone who has this problem please give us a step by step procedure so that we can reproduce this here?
        Corey
        Corey Rubadue
        Director
        Chaos Group
          Here it is. At least I can help, cause all bugs I found are reported:
          a) Open Rhino
          b) Open model, or make for example base surface as floor, and ball on it, it doesn't matter.
          c) Make light. Cone or rectangular, it doesn't matter too. Use any position of control points (middle of cone and end of cone, corners of rectangular lights) then select light and
          c.1 - open "Object propereties" by icon on toolbar, then select "Light" from list
          c.2 - Use F3 to open Obj. propereties
          and there is blank settings, check picture. I rotated there rectangular light, but light settings did not work when It wasn't rotated.
          darklight@cgart.cz
          http://www.cgart.cz
            I see what you mean for sure. I still cannot reproduce this. I am going to try on two other machines.
            Can you send me a simple scene file via e-mail that you get the problem in?
            Corey
            Corey Rubadue
            Director
            Chaos Group
              bag Light settings
              It occurs at me always - that is I have no access to Light when is active VRay Renders...
                Triar: What system do u use? Me Windows XP MCE 2005 (with SP2) and now Im talking with Crubadue on icq about this bug. I hope we will find solution.
                Betatesting and vray rulez & peace
                DLight
                darklight@cgart.cz
                http://www.cgart.cz
                  For those of you having this problem follow these instructions.
                  1. Close Rhino
                  2. Download the following file. http://www.asgvis.com/vrfrhino/Mscomct2.zip
                  2. Unzip the file in your X:\Windows\System32
                  3. Start Menu>Run>regsvr32 "X:/windows/system32/mscomct2.ocx"
                  4. Restart Rhino
                  "X" Is the drive letter where you have installed windows.
                  This is fixed for the next release.
                  The ASGVIS Team
                  Corey Rubadue
                  Director
                  Chaos Group
                    Yep, it works. I tried it with Crubadue yesterday thx for it
                    darklight@cgart.cz
                    http://www.cgart.cz
                      Thanks!
                      Yes, it`s works! Big Thanks, congratulations
                        yes that was my fault
                        My previous Nullsoft installers put that ocx file on your machines, but I must have neglected to put it in my new InstallShield installer. Whups!
                        Joe Bacigalupa
                        Developer
                        Chaos Group
                          Yes. Thats why it worked for testers who had previous versions and then reinstalled to version 5, but testers who tested first time version 5 hadn't this OCX so they had problems
                          darklight@cgart.cz
                          http://www.cgart.cz
